Fri, Feb 7, 10:25 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 7:37 am)
Subject: Allocating memory
rockets ( ) posted Fri, 20 July 2001 at 11:24 AM ยท edited Fri, 07 February 2025 at 10:07 AM
I use Poser all the time, but today it is telling me that I may need to allocate more memory to Poser. How do I do that? TIA
My idea of rebooting is kicking somebody in the butt twice!
bebop ( ) posted Fri, 20 July 2001 at 12:19 PM
If you are working on a PC you can't. If you are working on a Mac you can.
rockets ( ) posted Fri, 20 July 2001 at 12:41 PM
Thanks...I finally figured that out. It seems to be a problem with a dress obj. I was trying to use. It's weird, I used to could use it, but since putting the update on, it doesn't work. I don't know if that's the problem or not, but sure can't use that dress anymore. :-(
steveshanks ( ) posted Fri, 20 July 2001 at 4:31 PM
delete the rsr that sits next to the obj that'll fix it ;o)......Steve
rockets ( ) posted Fri, 20 July 2001 at 4:44 PM
Oh good...thanks Steve. Should I just delete all the rsr's on my hard drive?
steveshanks ( ) posted Fri, 20 July 2001 at 4:50 PM
no no ........well you could actually :o) but poser will build new ones so no only if you have an obj error, delete it and poser will build a new one.....you see the first time it loads an obj it takes ages as it builds the rsr but next time it'll load the rsr faster than an obj........unless the rsr got corrupt as in your case.....NEVER delete the rsr in the poser4 folder thats posers engine :o)......Steve
rockets ( ) posted Fri, 20 July 2001 at 4:56 PM
Thanks, and btw, I tried it and now it works!
