Sat, Feb 8, 11:19 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Subject: Python editor?
Cage ( ) posted Mon, 25 June 2001 at 7:39 PM · edited Wed, 05 February 2025 at 2:24 PM
I thought Tkinter or Ktinker or whatever it's called was supposed to be included with the ProPack. Was a Python script editor included? If so, can anyone tell me where in the Runtime directory I can find it? The "edit script" option just launches WordPad, which will only save as a text file....
bushi ( ) posted Tue, 26 June 2001 at 12:29 AM
I haven't found an editor included with the Pro-Pack. I have been using PythonWin and saving the scripts in a test folder under poserScripts. It works just fine so far. I've recently had to work the Mac make side of the aisle and have been using the idle that comes with MacPython. It also does a good job. TkInter is a different thing altogether. It's a set of GUI modules that let you create panels, buttons, sliderbars etc. Python and PoserPython scripts are by their nature just text files so any text editor will do to work with them.
Cage ( ) posted Tue, 26 June 2001 at 7:27 PM
Aha! I misunderstood, then. Thanks, Bushi. I will try PythonWin. For some reason, when I rename a text file with the .py suffix, it becomes "filename.py.txt" instead of "filename.py". Huh....
jbrugion ( ) posted Thu, 28 June 2001 at 4:59 PM
try www.scintilla.org if you want a straight editor. It does the color coding and tabbing for Python and it also does HTML, C/C++, etc. Nice for basic editing.
spiderone ( ) posted Fri, 20 July 2001 at 2:23 PM
i like to use the textpad32 text editor. it is nice and fast
