Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 11 2:52 am)
Poser (at least version 7 and maybe 8 by the looks of it) has problems rendering shadows of small props if that's all there is in the scene, you can either scale the prop up or add something else. I believe it's down to the way Firefly works out shadow maps ("Badly" I think is the expression)
My Freebies
Buy stuff on RedBubble
good afternoon. i seem to have run into a very odd poser rendering issue. i was rendering some images for thumbnails and i ran into a very odd result. which i first thought was a problem with this particular install of poser 8. so, i tried running it on poser pro, and i saw the same result.
so, i wiped the system, windows xp pro media center edition sp3. after the re-install (patched) i had the same result.
at that point i transferred the files to a windows vista machine, and tried again. and in doing so, i found it also showed the same result. yellow border
then i began to think it was probably the model. but, i had previous test renders of groups of items which looked fine. so, i decided to run a couple tests on other items i have created, with it, and they all worked fine.
the next 'logical' step was to find a similar shape item, which i found in
..poser8runtimelibrariespropsposer 8misc propscan
it is a simple two part prop which resembles a soup can.
i used the exact same settings, default lights, and render settings on firefly set for final.
and i received the same result. brown border
when i turn shadows off, i get an interesting effect. the lid object still cast a shadow, but the can does not. as illustrated in the red image
so, i then thought about it, and remembered groups of items worked, so i added the bowl from the same directory, which is part of the poser 8 default install. the end result is shown in the blue image
so, i began to experiment, and i found that items with a cyllindrical nature were even in groups providing the same shadow error, but the addition of a none cyllindrical item, as is depicted in the green image, works fine.
has any other here experienced this? and if so, have you discovered a solution?
