I think in Vue 6 you used Vue's help menu to add modules.
LVS - Where Learning is Fun!
As Peggy says you open the help menu in Vue. You then click on Registed Additional Modules and select Botanica.
You will then need to copy the registration code from the e mail that e-on sent you and paste it in.
From memory I think I had to use the keyboard shortcut of control-V to paste. I know I did in Vue 7.
You could just type it in if you prefer.
Hope this helps.
I've just uninstalled Vue 6 and reinstalled it to a different location (I've been planning to do this for a while). I thought that it would require that I registered the modules again so I could try it out for you.
Unfortunately Vue remembered all of the modules and installed straight to Pro Studio as I have all of the modules.
My help menu also does not show the add modules option but that's likely to be because I already have them all.
I found the original e mail from e-on for my Botanica module and it says it's in the help menu.
Anyone else out there who can throw some light on this please?
Make sure you have the latest update for Vue 6? I don't know of any other way for the modules to be installed.
I would fill out a support ticket at e-on. Sorry I can't help more, but I don't have Vue 6.
Dear Friend:
How can use the Botancia code to use Botanica in VUE 6 Esprit?
Thanks.
Fidelity2.
