Tue, Jan 7, 1:09 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: MorphFromOBJP6.py
hoplaa ( ) posted Mon, 19 October 2009 at 7:24 PM · edited Sun, 05 January 2025 at 9:15 AM
I have a script called MorphFromOBJP6.py by an unknown author which loads an OBJ and creates morhps from it. It is also supposed to create INJ/REM poses, but the script fails with an error in Poser Pro and 8.
Does anyone happen to know a script which successfully exports injection poses?
Edited to add that the script does create morphs but not the poses.
markschum ( ) posted Mon, 19 October 2009 at 10:11 PM · edited Mon, 19 October 2009 at 10:15 PM
what error ? In Poser 7 and up there is a parameter for tkinter which needs to have col changed to columns.
That script seems to be by svdl maybe.
hoplaa ( ) posted Mon, 19 October 2009 at 10:58 PM · edited Mon, 19 October 2009 at 10:59 PM
Yeah apparently it's by svdl as it creates a directory by that name at some point.
The error is about a variable which is used before it is declared (affectedActors). I don't know enough Python to fix it.
hoplaa ( ) posted Mon, 19 October 2009 at 11:33 PM
Actually I think I can, wil get back to it later.
