Ok then the only other thing would be a "clean" install, did you try that?
Cut your runtime from the Poser folder and put it somewhere safe.
Delete Poser using windows, navigate to your Poser folder on your "C" drive [it will be there] and delete it completely.
Re-install remembering to add all SR fixes, see if it runs.
If it does, delete that runtime and replace it with your original runtime, it should work, I have done this previously!
It's your call to do it though, I know it works but I take no responsibility if you do something wrong! ;)
Injustice will be avenged.
Cofiwch Dryweryn.
I misunderstood and thought you had just started using Poser. If you've been using it for years then this is not likely the problem. Also, this works if your on XP--don't know about Vista or W7. But if you want to try it anyway:
Right click on the desktop
Click Properties from the menu
Click the Settings tab
Click the Advanced button
Click the Troubleshoot tab
Bump the hardware acceleration slider down a notch. click OK and try to open Poser and see if it works. If not, bump it down another notch, and so on.
Just a long shot, but thought it might eliminate some possibilities.
These are the only four files in my P6 root dir that have a date after the most recent date of the files on the original P6 CD (6/02/2006).
They are all four dated the same date as the last installation date of the app.
uninstal.log
Poser.dta
PoserReg.dta
setuplog.txt
thank you for all the help - running XP Pro . . . I happened to remember I installed a couple browsers to look them over . . . Mozilla and another one on the 19th and I don't think these were the problem but wasn't conscious of any other changes, so I stuck my tongue in my pocket so I wouldn't swallow it and did a quick restore to the 18th - Poser opend without a hiccup . . .
I hate doing this because I don't know what kind of damage it might do to my files, but I had to get it back to working . . . and nothing else seemed to work . . .
Let's see if I can get the story straight . . .
A week ago, I installed Foxfire so I could see what it was doing to my sites; first thing, it required an install of QuickTime, which required Windows update to SP3, which caused my graphics driver to roll to original and caused problems . . . so when I did the restore, the problem was cleared up by undoing the installs which caused the driver problems for my graphics card . . . that's the only reason the restore to 5 days ago worked . . . otherwise, it would have required me to go download the newest driver and install it - which I will do anyway . . .
thought I'd not this just in case someone else has a problem . . . they sent me a link to the article:
Title: My graphics program keeps crashing or disappearing
URL: http://support.smithmicro.com/cs/smkb.cfg/php.exe/enduser/std_adp.php?p_faqid=2097
and answer to problems, links to drivers and also mentioned of hardware acceleration trick which I haven't done yet . . . but will if I need to.
Two days ago, I started Poser . . . it got as far as the screen credits and then it just disappeared . . .
I tried several times; rebooted and tried several times more, rebooted a half dozen times; then re-installed it; then uninstalled and rebooted and re-installed it . . . . nothing works! It gets as far as the credits screen and disappears . . .no errord, no nothing . . . .
anyone know what's wrong all the sudden? I've been using it on this system for almost a year now with no problems at all. XP Pro system and no recent updates of any kind . . . only thing I haven't tried is restoring back four days or so . . . O, an nothing new installed.
