Sun, Jan 12, 9:38 AM CST
Subject: Re FrenchTwist
Sviat ( ) posted Fri, 20 July 2001 at 5:32 PM · edited Fri, 09 August 2024 at 9:38 PM
The founder of a Hair named FrenchTwist is searched. Please answer this message or by eMail sviat7@netscape.net TIA Sviat.
Sacred Rose ( ) posted Fri, 20 July 2001 at 8:11 PM
Could it have been Anton Kiesel?
Chailynne ( ) posted Fri, 20 July 2001 at 9:54 PM
Seems to me it was jshoen from quite a while ago.
hmatienzo ( ) posted Sat, 21 July 2001 at 12:21 AM
I think Propsguild had it... are you sure it wasn't Anton K?
L'ultima fòrza è nella morte.
Jaager ( ) posted Sat, 21 July 2001 at 12:50 AM
From the Props Guild, from a year or two ago. Anton Kisiel it is. The problem I had in trying to texture it - aside from the difficulty in getting a usable map from a hemisphere, is figuring out which way the hair runs.
mikes ( ) posted Sat, 21 July 2001 at 8:33 AM
Jaager-- I tried to make a map, too. If you succeeded, could you post your map?
Jaager ( ) posted Sat, 21 July 2001 at 11:46 AM
Rather than try it again, I would use the prop as a last and morph a series of pre-mapped sheets over it. Before I could do that though, I would need to know the grain of the hair for the back half - which I do not.
Sviat ( ) posted Sat, 21 July 2001 at 1:16 PM
Good news: I remapped FrenchTwist ! :o) I think, this hair - good replacement for sold in stores. I has corrected their form (very slightly) and has made new and simple UV-map for this. Is necessary only to prepare all this properly, as I always do it. Probably I shall try to try on this hair on Vicky/Natalia... And after all I'm ready to post NewFrenchTwist in free stuff with map and three textures. With BIG gratitudes to the Founder.
hauksdottir ( ) posted Sat, 21 July 2001 at 2:56 PM
It helps if you've actually worn your hair in a French Twist (although mine is far too long, now). The best thing about this hair is that it is close enough to the head to be used under hats. Carolly
Sviat ( ) posted Sat, 21 July 2001 at 4:21 PM
Carolly ! This HairSet is very good if you are going strongly to incline a model or a head of model. There are no problems with visualization of gravitation :o)
