You import the trans maps into Bryce exactly as you would a texture map but you assign it to the transparency button instead. This has to be toggled to column B, then import you trans map exactly as you would a texture map. Up near the top of the Materials Editor is a small triangle thingie which pulls down a menu. On this you need to set blend transparency Hope this helps
How do I use Transparency maps I have created for Poser4 clothing into Bryce4?? I Can't figure it out. Can someone please help. Please be as specific as possible...im pretty new to all this. Thanks
