Mon, Jan 27, 6:56 AM CST
Subject: I have a problem With Conforming Clothes to V 4.2.
zerogalaxy ( ) posted Thu, 05 November 2009 at 3:52 AM · edited Sun, 26 January 2025 at 2:50 PM
I loaded up V 4.2 on poser8 scene.
I injected all morph channels like "Base V4" and "Elite V4" and "Morphs++V4" and :muscles V4" (Screenshot 1)img40.imageshack.us/img40/894/screenshot1pt.jpg
I change the Mat file with "MATerials Hi-Res!All_Natural" (Screenshot 2)
img410.imageshack.us/img410/638/screenshot2am.jpg
 Now I want to apply the cloth to V 4.2 I have a problem with this.
I do this work...
I Conform the cloth to Victoria 4 (Figureconform to...Victoria4)
In this case everything working properly. (Screenshot 3)
img59.imageshack.us/img59/61/screenshot3il.jpg
I apply poseSurrealityWarrior Maiden Tazi1 Morphs10-BodyMorphs then poseSurrealityWarrior Maiden Tazi1 Morphs11-Body1(Elite)INJ or i used one of These.
When I used other characters body Morph clothes Not conform to victoria4.(Screenshot 4) [img215.imageshack.us/img215/9774/screenshot4x.jpg](http://img215.imageshack.us/img215/9774/screenshot4x.jpg) What is the problem? Would you please Help me? Guide me in simple words and step by step because Im beginner.
kayjay97 ( ) posted Thu, 05 November 2009 at 7:51 AM · edited Thu, 05 November 2009 at 7:51 AM
Where did you get the outfit? Reason I ask is clothes at DAZ superconform..
1)Load V4
2)Load all Morphs
3)Select the body of V4
4)Load clothing piece
  1. Conform Clothing piece
    6Redo steps 3-5 for each clothing piece
Another thing that could be the reason is if the clothing piece does not contain the morphs used for the V4 character the clothes will not fit correctly. Example - The clothing does not contain the BreastsLarge morph but the V4 character you use  does then the breasts poke out
In a world filled with causes for worry and anxiety...
we need the peace of God standing guard over our hearts and minds.
Jerry McCant
cspear ( ) posted Thu, 05 November 2009 at 8:55 AM
Have you magnetized?
PoserPro 11 - Units: Metres
Adobe CC 2017
markschum ( ) posted Thu, 05 November 2009 at 10:26 AM
There are 3 things with conforming clothes for V4.
  1. If you change dial morphs on v4 after conforming and the clothes look wrong do the conform step again. (figures>conform)
  2. Use the magnetise clothing Pose- it does make a difference
3.Check if the clothing contains the morphs you used on V4, sometimes the clothing doesnt and you then have to use magnets to get it to fit.
hemi426 ( ) posted Thu, 05 November 2009 at 1:59 PM · edited Thu, 05 November 2009 at 2:00 PM
I think the problem you are encountering here is the third point from markschums post. Hongyu's corset does not have the morphs you applied to V4, so it doesn't conform properly.
You could use the "Morphing Clothes" utility from Dimension3D here in the marketplace to transfer the missing V4 morphs to the clothing.
After you posed the figure make sure you apply the magnetize pose that came with V4 to the clothing to transfer the joint control morphs.
zerogalaxy ( ) posted Fri, 06 November 2009 at 5:40 PM
Quote - Have you magnetized?
No,I don`t use magnetize.
cspear ( ) posted Sat, 07 November 2009 at 8:38 AM
Quote - > Quote - Have you magnetized?
I didn't, for a while, before I hit the sort of problem you're having. Magnetizing solved it.
NB Dimension3D has a free script for magnetizing which makes it much, much more convenient.
Adobe CC 2017
JoEtzold ( ) posted Sat, 07 November 2009 at 2:07 PM
That's the tazi morph you have used at V4. This is definitive not in the clothing. So it can't follow it even if this custom morph may be only a compilation of some of some combined standard morph dials.
One solution as said to use D3D's morphing clothes or you could try to reproduce a fitting using the fbm's in the corset and stockings to match V4's shape best.
