Fri, Jan 24, 3:51 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Delete method
spiderone ( ) posted Sat, 21 July 2001 at 7:13 PM · edited Fri, 24 January 2025 at 12:21 AM
To delete actor is done how if there is no method?
markdc ( ) posted Sun, 22 July 2001 at 3:12 AM
Attached Link: http://flashcardsonline.tripod.com/poserutils.html
If there is no method it can't be done. Hopefully the next release will give us full control of all Poser functions through scripting. I wanted to copy and paste keyframes, but there aren't any methods for that either.
Jackmon ( ) posted Wed, 25 July 2001 at 7:50 PM
To delete an actor you should first make it the current actor (scene.SelectActor()), and then call scene.DeleteProp(). Not as clean as it should be but it does work. something like: ball = scene.Actor("ball_1") scene.SelectActor(ball) scene.DeleteCurrentProp()
