Mon, Feb 10, 11:49 PM CST
Subject: .MC6 Material Library question
papillon68 ( ) posted Sun, 08 November 2009 at 9:31 AM · edited Mon, 10 February 2025 at 3:57 PM
Hi, I have a figure which has some parented props. It seems I can't create a material library that would contain also prop materials.
When I select my figure, and I click on the + sign to create a new material library set, it let me choose only the material belonging to the figure, while parented prop ones are not displayed.
Is this supposed to be this way, or there is a trick to do it ? Thanks again.
visit my blog:  www.alessandromastronardi.com
My Rendo Store
ockham ( ) posted Sun, 08 November 2009 at 9:36 AM
You'll need to select the prop itself first.  The prop won't appear in the main list of props when no figure is selected; it will appear under props AFTER you've selected the figure that owns it.
My python page
My ShareCG freebies
papillon68 ( ) posted Sun, 08 November 2009 at 9:57 AM
Hi ockham, thanks for your answer. I'm not sure I understand: I'm trying to create a .MC6 material collection including the figure material, and all the parented props materials.
When I select the figure, and I try to create the material collection, in the popup window I can only choose the materials belonging to the figure: no parented props materials are shown.
I'm on a Poser Pro Mac.
My Rendo Store
ockham ( ) posted Sun, 08 November 2009 at 10:15 AM
For a complete MC6 you'll probably have to save separate files for each prop
and edit them together.
Or save the figure as a CR2, which will include everything ...  and then locate
the materials in the CR2 and edit them into PZ2 (MATpose) form.
My python page
My ShareCG freebies
ockham ( ) posted Sun, 08 November 2009 at 10:41 AM
Here's a template for a PZ2 that changes a material on the figure itself and a
material on an attached prop.  (In this case the prop is a skirt.)
Note that I've shortened the material paragraphs so you can see the format.
version
    number 4.01
figure
    material SkinTorso
        KdColor 0 1 0 1
        KaColor 0 0 0 1
        KsColor 0.0196078 0.0196078 0.0196078 1
        TextureColor 1 1 1 1
        NsExponent 30
actor CowgirlSkirt
    material skirt
        KdColor 0.933333 0.933333 0.933333 1
        KaColor 0.2 0.2 0.2 0
        KsColor 0.498039 0.498039 0.498039 1
My python page
My ShareCG freebies
papillon68 ( ) posted Sun, 08 November 2009 at 10:44 AM
Well, thank you very much ockham, I was just searching how to create those .pz2 files and you were so kind to provide the best info ! Very much appreciated...
My Rendo Store
nruddock ( ) posted Sun, 08 November 2009 at 10:47 AM
I suspect that as Poser isn't listing the materials for the parented props, you'll need to make seperate MC6s for each prop and the figure they're parented to.
Why, because the material room only has one selected item and will either ignore any materials not present on that item or create new and useless entries which have no affect (which was the previous behaviour, PPro may have changed it).
Attempting to make a MAT pose would run you into all the problems normally associated with pose, props and naming.
The best solution would be to write a Wacro to apply the MC6s to the appropriate props, which is called from the MC6 for the figure.
papillon68 ( ) posted Sun, 08 November 2009 at 11:16 AM · edited Sun, 08 November 2009 at 11:19 AM
Thanks for your help ! About the .pz2 file, I have troubles making it work: when I apply the pose, it correctly assign the material to the figure but not to the props. Here is my template:
version
number 4.01
figure
material body
    KdColor 0.980392 0.980392 0.980392 1
    KaColor 0 0 0 0
    KsColor 0.843137 0.843137 0.843137 0.1
prop right_eye
material right_eye
    KdColor 1 0 0 1
    KaColor 1 0 0 0
    KsColor 0.984314 0.084314 0.084314 0
I really can't see what might be wrong ...
My Rendo Store
papillon68 ( ) posted Sun, 08 November 2009 at 11:29 AM
Well, I made a mistake: the prop material definitions should be outside the figure block:
version
number 4.01
figure
material body
    KaColor 0 0 0 0
prop right_eye
material right_eye
    KdColor 1 0 0 1
    KaColor 1 0 0 0
My Rendo Store
