Tue, Feb 18, 1:55 AM CST
Subject: How Can I Eliminate the Horizon?
BLT5150 ( ) posted Sun, 08 November 2009 at 3:05 PM · edited Mon, 25 November 2024 at 12:52 PM
In doing space scenes for SF work, I make images of planets, nebulae, starships,etc....
However, the appearance of the horizon in each image ruins the realism. How  do I get rid of the horizon, and create a seamless environment? I need to an image with no distinction between sky and terrain.
Thanks, in advance.
skiwillgee ( ) posted Sun, 08 November 2009 at 4:03 PM
Select a preset sky (s) under "installed/backdrop"
Or....
in skylab  turn off atmosphere and then turn off haze and fog.
It is simplest to use the "backdrop" skys
erosiaart ( ) posted Sun, 08 November 2009 at 11:09 PM
camera angle too..helps..
pakled ( ) posted Mon, 09 November 2009 at 11:10 PM
I've done a few. I delete the ground plane, then select Starfield (with 0 haze for clarity). Turn up the number of stars, but turn down the intensity (you get more stars, but not not as 'big.'
The trick is the sun; I tend to move it around the edges...then I'll use faint radial lights to bring up the detail. of whatever spaceships, etc., I'm using.
One thing to watch; if you put in planets, make sure the shadow doesn't fall across the planet...ruins the whole thing...;)
