Thu, Nov 14, 6:00 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Subject: Export Wavefront OBJ - Multi frame export - Frame Range: every nth frame possibl
VerlSnake ( ) posted Tue, 17 November 2009 at 7:25 PM · edited Wed, 13 November 2024 at 11:29 AM
Attached Link: Verlsnake's Allerlei
What I would like to do is: - Export a model for every nth frame in an animation
I know how to export models for every frame in an animation - via "Export Wavefront OBJ - Multi frame export - Frame Range".
But unfortunately, there's no option to tell Poser to export only every nth frame ...
Is there any unofficial way to export a model
  • for every nth frame
  • for each keyframe
  • for an arbitrary list of frames
    in an animation ?
bantha ( ) posted Wed, 18 November 2009 at 12:54 AM · edited Wed, 18 November 2009 at 12:55 AM
 Not within the standard gui, but I think this should be able to do with Python. I don't know if Python can detect the keyframes, but the rest should work.
-"Amazing Grace" Hopper
markschum ( ) posted Wed, 18 November 2009 at 1:07 AM
A python script would work. Every nth frame or by keyframe or by list of frame numbers can be done. You would need to build a filename yourself but thats not hard to do.
VerlSnake ( ) posted Thu, 10 December 2009 at 8:36 PM
I have something rudimentary in place - having used the existing python script 'PythonposerscriptsRenderControlexport.py' as a blueprint ...
BUT: Multiframe Export doesn't seem to function from script:
  • When I call
             myExportObject.Export('obj', 'File Format Wavefront', '/Keyframes/Keyframe.obj', exportOptions)
      with
             exportOptions[poser.kExOptCodeMULTIFRAME] = 0
      then the current figure is output
  • When I call the same method with
             exportOptions[poser.kExOptCodeMULTIFRAME] = 1
      then NOTHING happens ...
My script IS actually cruising the keyframes of the current animation, but the Multiframe Export method is not working properly ... A known bug ?
VerlSnake ( ) posted Tue, 16 February 2010 at 2:01 PM
New enlightenment: I don't need 'Multiframe Export' in this case; the 'Export' function exports the current keyframe object automatically !
So I've set
  • 'exportOptions[poser.kExOptCodeMULTIFRAME] = 0'
  • 'exportOptions[poser.kExOptCodeFIRSTFRAME]' NOT at all
  • 'exportOptions[poser.kExOptCodeLASTFRAME]' NOT at all
And all keyframe models are output automatically !
