Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Although this may not be an exact match to your problem you may like to take a look at this:-
I am having a problem with my imported BVH files in Poser, in that they contain Forearm Side-Side data when, anatomically, that should remain at zero and any movement like that should be in the Shoulder Twist. My BVH files do contain Shoulder Twist data, so I can't simply transfer the Side-Side data to the Shoulder Twist, the values need to "add."
I imagine that the logic behind a Python script to do this would compare the Forearm Side-Side keyframe values to the Shoulder Twist keyframe values, and then add the Side-Side values (either positive or negative) from the Forearm to the Shoulder Twist, so a Side-Side of, say -30 plus a Twist of +10 would yield a Twist of -20. The Side-Side values would then be all set at zero.
I tried this manually on a few frames and it seems to work, but I was wondering if a Python Script exists for this? (I'll ask this in the Poser forum as well.)
Thanks--Tim
