Wed, Feb 5, 11:56 AM CST
Subject: Help with a Bebop file
LeBurns ( ) posted Mon, 23 July 2001 at 11:15 AM ยท edited Wed, 05 February 2025 at 8:52 AM
I needed a black woman in a pic and remembered that I had downloaded Karol by Bebop. When I opened the zip file all that was in it was a black woman skin tex, and pic and a .obj file called Karolhead.obj. I assume the .obj is a head morph or something to make the models face, but how do I use it? The zip had no readme in it and while I know obj files are usually found in the geometries directory I have no idea where to put this one or how to use it once it's here. Any help would be appreciated.
Lovely Lady ( ) posted Mon, 23 July 2001 at 11:31 AM
You can put the obj file anywhere. To use the morph you load the P4 nude woman then click to select the head, then go up to to the menu item Object....load morph target. Then find the Karolhead.obj, select it and then name it if you want to something instead of shape 1, then click OK. Then set the new morph dial that appears on the head to 1.0. Then change the texture to the skin tex. You can then save it as a new character if you wish. Hope that helps.
LeBurns ( ) posted Mon, 23 July 2001 at 12:28 PM
That was it! Thanks a lot Lovely Lady. :D
