Tue, Nov 19, 7:42 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Poser 8: (un)Binding Events
Dizzi ( ) posted Wed, 25 November 2009 at 6:23 AM · edited Tue, 19 November 2024 at 7:28 AM
Did anyone manage to bind keyboard events to a wxPanel?
Is unbinding events possible? I'm getting a Python error when doing an Unbind, but I have no idea if that's a broken Python lib or me ;-)
semidieu ( ) posted Wed, 25 November 2009 at 6:47 AM
From what I know, it is not possible to do this for a wxPanel. It can be done for wxDialog I think.
nruddock ( ) posted Wed, 25 November 2009 at 3:02 PM
I can't see anything to suggest that you can't Bind key events to a panel, but the problem I supsect  you'll run into is one of the Panel having focus (aspects of the Poser GUI may exacerbate this) or making sure controls within the panel pass unhandled key events up the chain.
Dizzi ( ) posted Wed, 25 November 2009 at 3:32 PM · edited Wed, 25 November 2009 at 3:32 PM
Quote - I can't see anything to suggest that you can't Bind key events to a panel, but the problem I supsect  you'll run into is one of the Panel having focus (aspects of the Poser GUI may exacerbate this) or making sure controls within the panel pass unhandled key events up the chain.
 Yes, you're right, I shouldn't have tested that late at night, it works, if the panel is selected. Thanks :-)
I also found a way to stop Poser reacting to the pressed key:
Bind components of Panel to EVT_KEY_DOWN
and have the event handler do event.SetUnicodeKey(0)... I'm not sure if that's safe to do, but it works at the moment ;-) (maybe it stops when I try that again tomorrow ;-))
Dizzi ( ) posted Wed, 25 November 2009 at 5:37 PM
Probably better to use event.StopPropagation()
I've got still no idea, why Unbind gives
Traceback (most recent call last):<br></br>File "P:Poser 8RuntimePythonposerScriptsScriptsMenumousewheelposing.py", line 79, in EvtKey
self.Unbind(wx.EVT_KEY_DOWN, self.EvtKey)
File "P:Poser 8RuntimePythonlibsite-packageswx-2.8-msw-ansiwx_core.py", line 3916, in Unbind
id  = source.GetId()
AttributeError: 'function' object has no attribute 'GetId'
