Mon, Dec 23, 6:35 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 22 10:18 pm)
Subject: Animation woes
argus1000 ( ) posted Fri, 27 November 2009 at 2:20 AM · edited Wed, 27 November 2024 at 4:05 AM
Hi all,
I have a problem with BVH files that don't stand still. Sometimes, it is impossible to hide the feet of a character and I see their feet slide unnaturally with respect to the ground, even if the character is idle. It is not only the feet; it is the whole character that slides. How can I lock this character or make it stand still? In other words, how can I make this BVH file steady? Any clues would be appreciated.
Little_Dragon ( ) posted Fri, 27 November 2009 at 8:50 AM
After considerable experimentation with BVH files, I've concluded that Poser doesn't seem to do that good a job of scaling down the motion data to match the figure.
I often reduce the hip translation by ~50%, using one of ockham's Python scripts, which I'd modified specifically for that purpose.
Anakele sells a Python utility at Content Paradise which can help correct the sliding -- BVH Constraint.  He's posted a tutorial video on YouTube.
leezace ( ) posted Fri, 27 November 2009 at 4:17 PM
I have hundreds of BVH files and i doubt one of them actually works 100% with Poser. When a company does any sort of motion capture and sells it as a BVH it generaly means it is used for a few formats so not really being 100% compatable.
As pain staking as it sounds i take a BVH i like and then do all the adjustments needed though the wave editor. I never had much luck with python methods.
In fact i recently did my own motion capture avi (check out the video center "test walk") and got a brilliant bench mark for a walk cycle using the .avi as a background and just simply matching the poses. it took about a month to refine mind lol
Patience is the key, if it worked "out of the box" then everyone would produce great animations ;)
Good luck with your results.
V
argus1000 ( ) posted Sat, 28 November 2009 at 10:23 AM
Great tips, guys. I feel that this BVH constraints script might be useful.
