Thu, Jan 23, 8:43 AM CST
Subject: Zew 3d's Clothim/Clother
ghoyle1 ( ) posted Fri, 04 December 2009 at 10:27 AM · edited Sat, 10 August 2024 at 4:26 AM
I'm thinking about purchasing some of Zew3d's Clother/Clothim products, but I'm not sure what choices to make. If any of you have used their products, I'd be grateful for some advice. Mostly I'm not interested in actual clothing, but rather the tattoos, bruises, injuries, etc.
I have a fairly large collection of V3 and M3 products, so I'd probably be more likely to buy Clother and Clothim (I think). Are Masker and Eyer for V3/M3 only?
If I wanted to use V4 and M4, would I then be required to buy Clother Hybrid and Clothim hybrid? Do these products also work on V3/M3?
IU appreciate any advice on this matter.
Guy Hoyle
basicwiz ( ) posted Sat, 05 December 2009 at 4:16 PM
 You are on thr right track. The scars, wounds, tattoos et al work great. The underwear is acceptable if you don't get too close. The regular clothing is far less successful.
I own the pair of programs for V3/M3 so can't comment on the hybrid.
ghoyle1 ( ) posted Sat, 05 December 2009 at 4:42 PM
Thanks for the info. I have another question. I note that Masker and Eyer both work on V3 and M3. Since the Millenium 3 figures can pretty much share textures, wouldn't it be possible to use just one program for V3 and M3? Or will the Clothim program not load textures built for Clother?
Guy
basicwiz ( ) posted Sat, 05 December 2009 at 4:54 PM
Sorry, no idea. I don't own those.
ghoyle1 ( ) posted Sat, 05 December 2009 at 5:11 PM
Oh. You do own Clother and Clothim, though, don't you? The ones for M3 and V3? Can you load textures you bought for V3 (for example) on M3?
Thanks again,
Guy
TrekkieGrrrl ( ) posted Sat, 05 December 2009 at 5:37 PM
 Although I don't own either oof the ClothXXXX programs, I've noticed that there's also one called "hybrid" - that one at least ought to work on both the male and female generatio 2 characters.
There are subtle differences between the mapping of V3 and M3. Most notably the navel which is placed differently.
Theoretically they should be able to share textures.
And bear in mind that I don't know exactly WHAT Cloth[anyone] does, but you should be abl to convert the results with UTC if they w9on't work immediately
ghoyle1 ( ) posted Sun, 06 December 2009 at 1:47 AM
Thanks for the response, TrekkieGrrrl... I do have UTC, so I can do the conversions, and I don't foresee the navels being a problem. I think there are separate Hybrid programs for V4 and M4, however; the "hybrid" part seems to be that there's no separate Masker or Eyer program for the 4th gen models.
Again, thanks for the info; I'm a fan of your work!
Guy
