Sat, Feb 15, 12:02 AM CST
Subject: Downloads
Lynny0780 ( ) posted Tue, 24 July 2001 at 1:15 AM · edited Fri, 14 February 2025 at 1:18 PM
i downloaded some bryce objects from here, and i dont know how to get them opened to use in bryce. can anyone help me?
KenS ( ) posted Tue, 24 July 2001 at 1:22 AM
Attached Link: http://www.winzip.com
try winzip if you cant open them and they have a .zip extension
Lynny0780 ( ) posted Tue, 24 July 2001 at 1:24 AM
i did unzip them... i cant get them to open tho so that i can use them.
clay ( ) posted Tue, 24 July 2001 at 1:54 AM
Did you open Bryce and go to the create palette and then import them in?
Do atleast one thing a day that scares the hell outta ya!!
hewsan ( ) posted Tue, 24 July 2001 at 2:49 AM
Depends on the extension - ie if obj, dxf, or 3ds, which are the most common,then do an import object command, and unless it's a very large file, normally will have no problem & if the 3ds or obj has texture coordinates, you can import the maps and they will place themselves on the model. Need to notice what the file extension is to decide how to bring them in. :)
Lynny0780 ( ) posted Tue, 24 July 2001 at 3:24 PM
its an .obp file..
KenS ( ) posted Tue, 24 July 2001 at 4:05 PM
with .obp files, click the arrow below the CREATE at the top of the screen, select a section to import it into, then click import and locate the file. once loaded simply select it and click the checkmark and it will load the file into your scene.
