Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 05 11:51 pm)
Attached Link: http://www.runtimedna.com/HARDGore-Syringe.html
Like this?Sitemail | Freestuff | Craftythings | Youtube|
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it
into a fruit salad.
? You know, you can move the "syringe" part to give you the "dose" you want ;) And you can make the syringe itself smaller.
into a fruit salad.
The Syringe is hosted at ShareCG. I just tried it andit works fine. Perhaps ShareCG had a momentarily downtime?
Also I have the NEEDLE on it's own as part of a pack of "pointy stuff" - it's available over at raunchyminds dot com.
Hm... I guess I should move my things OFF ShareCG if they aren't stable enough...
I'm just wondering what one would use a hyperdermic needle for. A hypodermic needle allows access to the layer just beneath the skin, as the name implies. I'm assuming a hyperdermic needle would blow through the skin and some other layers as well. Are these used for bone extraction? Do they have excessively long needles? Do they come out the other side?
Inquiring minds want to know.
Lotus 123 ~ S-Render ~ OS/2 WARP ~ IBM 8088 / 4.77 Mhz ~ Hercules Ultima graphics, Hitachi 10 MB HDD, 64K RAM, 12 in diagonal CRT Monitor (16 colors / 60 Hz refresh rate), 240 Watt PS, Dual 1.44 MB Floppies, 2 button mouse input device. Beige horizontal case. I don't display my unit.
I'm looking for a hyperdermic needle for poser. I bought several medical medical themed sets, but no needle. Can any one please help? I need a high rez, detailed needle for close ups. It need to be a needle model that can be used on a commerical project, a book cover.
