Sat, Jan 11, 3:09 PM CST
Subject: Need Help Saving Props
MrDayTona ( ) posted Mon, 23 July 2001 at 8:35 PM ยท edited Sat, 11 January 2025 at 2:34 PM
I am trying to save a prop with a lot of transparency but when the image appears in the Category Menu, its faded. How do I save the Prop with the proper transparencies yet have the Menu Image look as though it was rendered?
Jaager ( ) posted Tue, 24 July 2001 at 3:28 AM
Two ways to do it: Save a render of the prop - dimensions = square. Open the one sided square from the primatives - texture it with the saved render and save this to the props library - different folder - same name as your prop - delete the pp2 and overwrite the Poser RSR of your prop with this one. Reduce the render to 91 x91 and save this as a PCT file. Use the PCT to RSR converter to make an RSR of it and over write the Poser generated RSR in the Library. The converter has been in Utilities here.
bloodsong ( ) posted Tue, 24 July 2001 at 6:15 AM
whaaa??? nah man. render your prop, as if you are taking a thumbnail snapshot of it. paste to background. now scoot the camera so you dont see the prop, only the picture of it. with the prop still selected, save to the library. :) much easier!
Cybermonk ( ) posted Tue, 24 July 2001 at 10:52 AM
Great tip bloodsong. I just tried it and it works like charm.
____________________________________________________
"The true sign of intelligence is not knowledge but imagination".
Albert Einstein
MrDayTona ( ) posted Tue, 24 July 2001 at 6:23 PM
Excellent Stuff. It Worked
