Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
I've just tried it. I used both together for one character, and just the IK for the other character. Worked like a charm. I guess I was trying to move the character too quickly and too radically, which hborre cautions against above. Also, sometimes I tried to pull the limb I put the IK on. I guess I should move any part BUT the limb the IK is on, huh?
Well, thank you all very much for your help. I'm getting new enjoyment out of Poser.
With IK on you will find the translate dials for the foot become visible. That is how you position the foot and ik will adjust the leg. You can adjust the leg a little bit but the foot wont move. Use the dials and you should not have problems. Sometimes the leg goes wierd, just select the upper leg and shin and set the rotate dials to 0 , IK will recalculate.
I'm wondering if there's a way of attaching (besides "Conform To" and "Parent To") a character's foot to a floor (as an example). Then, I'd like to be able to move or tip the character's hip, or bend the character's abdomen or chest, and still have the foot remain attached on the floor. The result would be an arc in the character's body without having the character float away from the floor.
Is there a way to accomplish this?
