You could always merge the images in Vue and then if your computer can't handle it send it off to a renderfarm.
Jon
DA Portfolio - http://jonj1611.daportfolio.com/
compositing cna be na art itself :)
i've done it for years as often you'll find small errors, or things that need tweaked etc etc
so I may render a small area with a change to a material, and layer that over original image and so on.
as Bruno notes, however you could lose shadows, so try rendering the left side of an image, and the right side seperately and composite them?
also, optimizing objects and textures helps a lot
so does setting display options to show only wireframes with no textures applied
"I'd rather be a
Fool who believes in Dragons, Than a King who believes in
Nothing!" www.silverblades-suitcase.com
Free tutorials, Vue & Bryce materials, Bryce Skies, models,
D&D items, stories.
Tutorials on Poser imports
to Vue/Bryce, Postwork, Vue rendering/lighting, etc etc!
FCLittle,
You can render light and shadows far more accurate and above all artistically by the simple expedient of creating an underpaint mask and paint yourself. You know, like Rembrandt did.
To get started try this. Make a new layer above your other layers and hold the alt-key down while you do this. In the dialog that appear choose overlay and check for “Fill with overlay-neutral color (50% gray)”. Set your brush to for example 50% opacity, then you can paint light with white color and shadows with black. You can also try with subtle colors. Experiment with the opacity.
If you export the alpha-channel together with the colour render of the foreground scene/image, you can clip out the background atmosphere (using the alpha-channel as mask), just be sure not to render infinite planes in the alpha-channel (uncheck in the render options).
Also, the z-channel can be used to fake mist, using it as a mask (maybe enhancing the contrast (autolevels or manually)), and dragging a gradient over it on a separate layer (then adjusting the opacity etc.) .
Hello all....
I was hoping someone could point me in the direction of a tutorial for blending two or more pictures rendered in Vue in Photoshop CS2.
Thanks!
