Thu, Feb 27, 12:08 AM CST
Forum Moderators: RedPhantom
Subject: Victoria 4 and Poser 8
tinman_prime ( ) posted Fri, 11 December 2009 at 4:59 PM · edited Wed, 26 February 2025 at 9:26 PM
Victoria 4 will not install normally in Poser 8.  Apparently P8 has a new way of installing runtime libraries.
Does anyone know how to get Victoria into the program?
Thanks!
vholf ( ) posted Fri, 11 December 2009 at 5:07 PM
I didn't have any problems installing V4 in Poser 8 or any other version of poser. If you use Windows Vista or Windows 7, take a look at This thread.
FightingWolf ( ) posted Fri, 11 December 2009 at 5:13 PM
I didn't have any problems either. I had to install it in the same folder as the the Poser.exe file.
hborre ( ) posted Fri, 11 December 2009 at 6:15 PM
You should provide more specific detail to how you are installing V4
thefixer ( ) posted Sat, 12 December 2009 at 1:41 AM
No problems here either, Windows 7 now but had it under Vista and XP previously.
Injustice will be avenged.
Cofiwch Dryweryn.
Morana ( ) posted Sat, 12 December 2009 at 11:18 AM
On a completely clean re-install on a new hard drive, I ran into a problem installing the gen 4 models because of a missing file the older models came with.  (No idea what file that is anymore, though.)  I found the easiest solution is to install an old M3 (or maybe V3) first, then everything else installed just fine.
Not sure if that's the problem you're running into or not.
lady-morana.deviantart.com
