Vue actually uses Poser to do the rendering of the skin shaders (at least I think it does.) Uses up serious amounts of resources though. If you want good looking skin shaders in Vue, look at getting SkinVue over at Cornucopia3D. Much better
My Freebies
Buy stuff on RedBubble
I differ with Frank here, we always have [LOL], Skinvue is a great tool for sure especially if resources are tight, However I import using the Poser shaders, most work ok and look just as good as in Poser IMO....But, there are some skin shaders for example that don't come in right, some of the shaders can appear as black squiggly lines on the texture that look a bit like worms going through the skin, cool for some scenes but not if you don't want them there. On the whole I have excellent results with the Poser shaders inside Vue, always have.
For me, if resources are tight go with SkinVue, if resources are plentifull stick with shaders.
Just my opinion of course.
Injustice will be avenged.
Cofiwch Dryweryn.
In the long run I would learn to use Vue's shaders, but since I'm fairly comfortable with Poser's shaders I would want to use them in the short term.
I have Vista 64 with 8gigs of ram so hopefully that will be enough.
Anyway I'm still slugging t along with the free version of Vue to see if I like it. And budgeting to see if I can afford the $300 for the minimum capabiities that I need. :)
I aim to update it about once a month. Oh, and it's free!
Hi friend, ok if this is the same problem as Vue 7 had then there is a work around, try this. Note this will only work if it's the same issue as Vue 7 had, I have to say though that I've not seen this in Vue 8 myself. We commonly refferred to this as the "Hulk" issue in Vue 7, [LOL].
Now look at the diffuse channel of your character skin inside Poser, if it's a light blue colour you need to change it to pure white, that should sort out your green skin [if it's the same issue].
If it is that you also need to report it to e-on!
Cofiwch Dryweryn.
Quote - Can't use custom textures with Skin Vue, very limited:)
Sorry but I use custom textures all the time in SkinVue. Very easy to use
My Freebies
Quote - > Quote - Can't use custom textures with Skin Vue, very limited:)
Me too. Most end-users though just want to import and render their newly bought content without putting much effort or thought into a scene. They think their high-end system will make the art for them.
you create green people in vue. you must be evil.
Love esther
I'm looking to upgrade my render program to either Carrara or Vue. I already have Carrara so I was just going to use it when I noticed that Vue 8's 3D Import claims to support Poser's shaders.
I love Poser's shaders and I've mostly figured them out so being able to use them in Vue qould be a huge benefit to me.
How well do the shaders actually import to Vue? Do they look the same, or is tweaking required. Does it support all of the nodes for the Poser shaders?
