Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 20 6:55 am)
I see that the background images can stand on their own, they serve more like a backdrop than an interactive scene. This is what I recommend:
Install a one-sided flat square plane from the Primitives Library. It does not have to be hi-res. In it's Properties panel, set your scale x and scale y to 2500 each (or whatever pixel resolution dimension the final image represents). Turn off cast shadows. Enter the Material Room and connect an Image_node to the Poser Surface's Alt_Diffuse. This should make your square image self illuminate and not receive shadows from other objects in the scene. Make certain that the Diffuse_color and Specular_Color are set to white (255,255,255) and their values set to 1. If you want to see the image in Preview, also connect the Image_node to Diffuse_color. Go back to your Pose Room and now scale and move your square within the scene.
Here are a couple of scenes in which I use this technique:
http://www.renderosity.com/mod/gallery/index.php?image_id=1885493&user_id=343328&np&np
http://www.renderosity.com/mod/gallery/index.php?image_id=1884989&user_id=343328&np&np
Let us know if this is exactly what you would like to accomplish.
I trying to work out how to load a background into poser 8 correctly. When I import one and I get the pop up message about the size of the document window size is different to the background I am trying to load, I select for the document window to be sized the same as the background the background then loads but there is overlap of the document window on both sides of the background.
Could someone please tell me what I am doing wrong and are there any poser 8 tutorials available?
Thanx for any advice
