It might help if you are clear at what you are trying to do.
Certainly you can host poser figures in 3ds max with plugins, but it sounds like you are asking if you can use models created in 3ds max within the Poser application.
Please confirm what you are looking to accomplish.
Shawn
McCarthy
www.defyallchallenges.com
I'm sure you could download the trial of 3ds max, and use that to export your model as obj.
Shawn
McCarthy
http://www.google.nl/search?hl=en&source=hp&q=convert+3ds+max+to+obj&aq=2msx&oq=3dmax+to+obj
Page of goodies for converting 3d max to OBJs
Most of which either say "use 3DS MAX" or No - you can't :biggrin:
My Freebies
Buy stuff on RedBubble
Quote - http://www.google.nl/search?hl=en&source=hp&q=convert+3ds+max+to+obj&aq=2msx&oq=3dmax+to+obj
all require Max to be installed to do the conversion.
Max is a proprietary format that Autodesk have not allowed others to play with. tis most annoying...
Quote - Sorry I founfd you the page
,I dont have the time tonight to do the rest for you
,I was looking f for the exact same issue and I found one although in the end I found the model i need in OBJ any way.Its ther youll just have to look.
You misunderstand me. I am well aware that there are NO free converters between .max and anything else. I was just clarifying the fact that none of your links will do what the OP needs
My Freebies
The sort of reaction to the 3ds format as written by the above posters is to be expected by folk who are mostly use 3D as a hobby and use it badly.
There is most probably an element of jealousy amongst their ignorance. :)
Apart from being the most widely used object format it is also the most stable.
A FREE program called "Imagine" will import and export objects in a "3DS" format very well indeed if that's what you want !
Just search for "Imagine 3D" and down load what is probably one of the best little FREE 3D programs there are.
3DS has some serious drawbacks as a format. See here for information and has a limit on the number of polygons per object (65535 if I recall correctly)
You could hardly call .3DS the "most widely used object format," I'd suggest that honour goes to the .obj format
My Freebies
Can you use 3d max pros in Poser, If so how?
Thanks
