Fri, Nov 22, 11:30 AM CST
Subject: What would cause a character head to totally inflate when a morph is injected.
lululee ( ) posted Mon, 21 December 2009 at 10:15 AM · edited Fri, 22 November 2024 at 11:29 AM
Hi, I have a customer who is having a problem injecting  a character morph into V4 in Poser6.
When he injects the morphs into the character body nothing happens to the body but the head inflates.
  i have never had this problem . The morph is made with Daz Elite, Daz A4 , Daz V4 standard morphs and works fine for me.  All the morphs are installed on his machine.
  Any insight would be much appreciated.
cheerio
lululee
Winterclaw ( ) posted Mon, 21 December 2009 at 10:21 AM · edited Mon, 21 December 2009 at 10:24 AM
He might have exported it to a .obj in a modeler in the wrong ratio.  IE you set it to be .50 when it should have been .25.  That's usually what happens to me.
If that's the case, tell him to reload the head geometry from the zip.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
lmckenzie ( ) posted Mon, 21 December 2009 at 11:08 AM
Balloon head? I've had it happen injecting a character morph which states that it is for V4.1 into V4.0 (? - too many Vickys, I get confused :-) In this case, there are two moprhs, head and body. The head morph works as expected but injecting the body makes the head balloon. Everything works fine on the proper Vicky 4.1. *
"...nothing happens to the body"*
In my case, the body morph does work. I suppose It's possible that if the body morph isn't dramatic, he may not be noticing because the big head is so distracting. For me at least, V4 is nude and V4.1 (and presumably 4.2) have the ugly painted on purple bikini.
lululee ( ) posted Mon, 21 December 2009 at 11:28 AM
Hi,
Thanks for all of your help.
I took a line of code of code out and hopefully that will solve the problem.
cheerio
lululee
FrankT ( ) posted Mon, 21 December 2009 at 1:54 PM
I get that sometimes.  What I do is select the figures head and I usually find HeadSize is set to 1
Reset it to 0 and the head goes back to normal
My Freebies
Buy stuff on RedBubble
lululee ( ) posted Mon, 21 December 2009 at 2:04 PM
Thanks Frankt,
 I am sending this post to my customer.
cheerio
lululee
lmckenzie ( ) posted Mon, 21 December 2009 at 2:44 PM
"Thanks Frankt"
Ditto. I just checked and indeed something is setting the headsize to 1 - not that I ever noticed there was a headsize to begin with :-)
FrankT ( ) posted Mon, 21 December 2009 at 2:49 PM
Glad to be of service :biggrin:
My Freebies
NoelCan ( ) posted Mon, 21 December 2009 at 3:00 PM
I got this just the other day..  I tried to inject V3 morphs into V4 by accident.  Hey presto..
I was working in Poser Pro 2010 beta..   Not a software issue so I did not report it..
Dave-So ( ) posted Mon, 21 December 2009 at 5:28 PM
hmmmmm ... big ego ?
Humankind has not woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound together.
All things connect......Chief Seattle, 1854
xenic101 ( ) posted Tue, 22 December 2009 at 6:19 PM
There is a typo in one of the morphs in the INJ files. Double check all the names carefully. Watch for capitalization and plurals (several of the 4th gen morphs have a ThighsSomething channel in the BODY but a ThighSomething channel in the actual bones)
For some reason, Poser since at least 6 and probably earlier takes these mis-matched morph settings and dumps them all into HeadSize
