Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 1:30 pm)
You probably will have to download SR2 (it incorporates the hot fix and SR1). Also download the current Flash , IE and driver updates.
Most of the "out of memory" errors come from too much junk in Cache created by everything. If you have been working Poser for a few hours-close down Poser, clear your cache, another thing that can cause crashes is selecting Poser menus etc in rapid sequence, The computer tries to follow and may stall. That applies to all software products. At least that what usually causes mine to freeze, not respond, etc. When I slow down a bit, that helps a lot. Jan
Thanks for the advice. Back then when I was still using Poser 7 this "out of memory" crash seldom happens, I can render a scene with four figures without any problem. Now however in Poser 8 I can only put two figure at max and I can still having crashes. May be Poser Pro 2010 can resolve this problem once it comes out?
I've been pulling my hair out trying to render a scene in P8 with five V4's all decked out, and I'm down to almost draft settings and still running out of memory before it finishes. Or it finally finishes with huge black holes everywhere. I'm not doing another render like this ever again.
@ Morana: I would also re-evaluate components in your scene. Are you running displacement maps, bump maps in all your materials? Is it necessary? If so, is the displacement bound set higher than 0? Disp. bound = 0 will cripple your render. Material room Diffuse_value should be lower than 1; reset those to 0.8 - 0.7.
@ GhostWolf: I seriously doubt those problems will go away with PoserPro 2010. We will be getting another variable included in the mix: gamma correction + IDL!
Thanks for the tips. I was just trying to put together a simple Christmas render with five figures, a tree, and a few gift boxes. I managed to cobble it together in Photoshop from the bits and pieces I had managed to get to finish rendering. I didn't think to set the bucket size to lower than 32, and it was at two threads and separate processes.
I didn't see any displacement maps, just bumps. But the Min Disp Bound is greyed out at 0.
Always more to learn and settings to dig through. :)
Hmmm,
I have no issues with 4 - V4's loaded with AerySoul (Large Textures) Products and all have real strand based hair...
Bucket 32
Shade Rate .25
R/T 1
Disp Enabled
.001 Min Disp Bnds
Separate Process
4 threads
Irr Cahce @ 90
Pix Smpl @ 10
Render Time 40min +/-
"Most of the "out of memory" errors come from too much junk in Cache created by everything. If you have been working Poser for a few hours-close down Poser, clear your cache...."
Where can one find the cache, and how can it be cleared?
Apologies if this has been discussed before. I've tried a forum search, but mainly returned posts specifying Irradiance Cache settings.
Hmmm,I have no issues with 4 - V4's loaded with AerySoul (Large Textures) Products and all have real strand based hair...
Bucket 32
Shade Rate .25
R/T 1
Disp Enabled
.001 Min Disp BndsSeparate Process
4 threadsIrr Cahce @ 90
Pix Smpl @ 10Render Time 40min +/-
I've always had Min Shading Rate at .01 in my final render settings. Wonder if that's where I'm blowing myself out.
If one were to purchase Poser 8 RIGHT NOW...do you still have to get the service releases or is the current for-sale version up to date, all hotfixes and service releases in place?
I'm NOT asking about the CONTENT updates but the actual program itself.
