Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Looks GOOD!
Since I haven't seen the threads that claim otherwise...
What is different in Poser 8 (yes I know about the IDL and such but what does it mean for such a render? What must you do differently?)
Start out simple, use a standard lighting setup in white (key, back, rim) - forget about all the tricks you have learnt and build it up slowly. All my old light sets (especially bought ones) dont work anymore, they look awfully bad. Set up one light after the other and dont forget the shaders - P8 thinks different. The results are more straightforward than ever before. This one above was really easy to do and I am using white planes for the lighting (somehow area lights) and a skydome for a general light.
Heh then I gues sI'm in luck. I have yet mo make my own "perfect" lighting se4t for Poser - and I've been using the program since Poser 4 L So it won't be hard to "forget all my tricks" as I really have none, other than making sure my lights are generally greyscale (As in... the main light is mostly white and the other are some shade of grey)
Ever since I bought the Terra Dome from RDNA I've been using that and its lights a lot. It makes most things look NICE!
Attached Link: http://www.renderosity.com/mod/gallery/browse.php?user_id=309619
I do not know why the lights work better in P8.. But here is one Very Happy person that they do..I have been posting images done with a single inverse square point light. no IDL..
Quote - Start out simple, use a standard lighting setup in white (key, back, rim) - forget about all the tricks you have learnt and build it up slowly. All my old light sets (especially bought ones) dont work anymore, they look awfully bad. Set up one light after the other and dont forget the shaders - P8 thinks different. The results are more straightforward than ever before. This one above was really easy to do and I am using white planes for the lighting (somehow area lights) and a skydome for a general light.
I'm not sure what you're doing, but all my old light sets work perfectly fine in P8, they look even better when rendered in P8 the before. SM didn't do that much about the regular lights at all. Every light set I've created in pre-8 versions work well in P8, every light set I've created in P8, works well in previous versions.
You don't have start thinking differently then before, P8 lights work the same as before.... unless you use IDL. But you've not stating that you do (but I've got the feeling that's what you're talking about). If you use IDL old sets don't work well, you to start thinking differently. If you don't use IDL (and enough people don't) there's no reason to think differently, most likely your renders look better then before.
Quote - Looks GOOD!
As long as you don't use IDL you don't have to do anything differently. My cars still look nice and shiny without IDL, using 'old' light sets or 'old' light techniques. I'm not using P4 or P5 techniques, those are already outdated since P6. But everything I've been doing since P6 still works fine...... even better!
Food for thought.....
Quote:- "I'm not sure what you're doing, but all my old light sets work perfectly fine in P8, they look even better when rendered in P8 the before. SM didn't do that much about the regular lights at all. Every light set I've created in pre-8 versions work well in P8, every light set I've created in P8, works well in previous versions.
As long as you don't use IDL you don't have to do anything differently. My cars still look nice and shiny without IDL, using 'old' light sets or 'old' light techniques. I'm not using P4 or P5 techniques, those are already outdated since P6. But everything I've been doing since P6 still works fine...... even better!"....end Quote..
I beg to differ, there are significant differences in the look of scenes even without IDL. There are more features with each light.. I am now able to think like a photographer when I am lighting a scene..! IMHO most lightsets do not work as well in P8, but by looking through the shadow light cams and tweaking then re-saving they are generally OK.
