Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 4:22 pm)
After several frames have rendered, open Task Manager and see if there are several instances of the FFrender process running simultaneously.
OSes: Win7Prox64, Win7Ultx64
Hi
I see this behaviour from the slower Windows machines on my network. I'm looking to see whether its a network connection timeout issue but I can't always reproduce the problem.
If your issue is reproducable , ie it happens every time you use a particular file. its worth speaking to Smith Micro about. Meanwhile I'm going to try the Pro beta after the holidays.
regards steve
Hi
I've had no problems like that one, which sounds like some port blocking process that might happen with a mis-configured firewall. I'm running a mix of mac and PC with few regular issues touches wood
Have you tried cold starting the network in a router > switch > clients sequence before you start the render? Sorry don't know what else to suggest without knowing more.
regards steve
i have 10 computers on a render farm. I am rendering a 512 frame animation as image files. For some reason most of the ten comuters get stuck on a frame after rendering for a long period. 4-5 hours approx. Anybody have this happen? Thanks.
