Fri, Nov 22, 9:12 PM CST
Subject: Getting Rid of Tabs in Poser 8...
onimusha ( ) posted Sun, 03 January 2010 at 6:33 PM · edited Fri, 22 November 2024 at 4:59 PM
Online Now!
Older poser versions had a way of getting rid of un-needed tabs... like the faceroom for example.  Is there a way to do it in Poser 8?
vholf ( ) posted Sun, 03 January 2010 at 7:24 PM
I belive that would require you to modify the interface's XML files and I don't think that's even legal, so short anwser, no.
TrekkieGrrrl ( ) posted Sun, 03 January 2010 at 7:57 PM
 Why wouldn't it be legal? It's not like he's selling it with the tabs removed.
Try a search for ContentParadise.. there were methods posted back when ..er..Poser 5 I think came out.. about what to write, and where - to get rid of that. Ought to function for all tabs.
onimusha ( ) posted Sun, 03 January 2010 at 8:38 PM
Online Now!
It's absolutely not illegal to modify Poser in that way.
I've done it with P5 and P6.  Are the methods still the same?  I don't remember how to do it, but I could probably dig up the answer...
LukeA ( ) posted Sun, 03 January 2010 at 10:51 PM
Do the tabs really need to be removed? Just curious why you would want to.
LukeA
My latest novel
onimusha ( ) posted Mon, 04 January 2010 at 5:03 AM
Online Now!
Mostly because there are several tabs I never use like the hair room and the face room.  Yet I find myself clicking on them accidently and it interrupts my workflow.
bevans84 ( ) posted Mon, 04 January 2010 at 5:17 AM
I've always wished the rooms links were at the top like the file menu. The tabs are a waste of workspace, the P8 tabs are better, but still a waste.
LukeA ( ) posted Mon, 04 January 2010 at 10:52 AM
Quote - Mostly because there are several tabs I never use like the hair room and the face room.  Yet I find myself clicking on them accidently and it interrupts my workflow.
Ahhh makes sense!
LukeA
My latest novel
Adom ( ) posted Tue, 05 January 2010 at 7:29 AM
NOTE!!
I have no idea about XML files - but what I described below wrorks for me just fine.
  1. I managed to get rid of selected TABs by editing "roomTabs.xml" file (located in "ui" folder).
2 .The only way I found to remove the WHOLE BAR with tabs was to change "bottom" value in:
Widget name="RoomTabSet"
set that value to 1 (there are 2 places to change it) --- doing that you do not get rid of the bar but only make its heihgt = 0 - so it is not visible enymore.
onimusha ( ) posted Sun, 17 January 2010 at 3:36 PM
Online Now!
This is what I tried...
I deleted all of the text paragraphs that had to do with the tabs.  When I started up Poser again, all of the tabs were there, but they just didn't have names.
What did I do wrong?
onimusha ( ) posted Sun, 17 January 2010 at 3:41 PM
Online Now!
Never mind, I did it...
Deleted all of the Tab Width Widgets...
Thanks for the advice...
