Mon, Jan 6, 10:19 PM CST
Subject: Prop or figure search
tonymouse ( ) posted Mon, 11 January 2010 at 6:45 PM · edited Mon, 06 January 2025 at 10:03 PM
I am lookng for a figure or prop most simiar to the scaloped Fin/crest found on image comic's Savage Draqgon. See link  http://www.dynamicforces.com/images/davagedragonbust.jpg
I know I have seen somthing very similar but I can't remember where, and all of my searches have come up empty.
Little_Dragon ( ) posted Mon, 11 January 2010 at 7:04 PM
Traveler's Organica 2 - Mermen (for Michael 2) comes immediately to mind.
tonymouse ( ) posted Mon, 11 January 2010 at 9:06 PM
Thanks LD, I happen to have that set already, I looked at the head fins they are a double set with both curving outward, I tried to reduce them on the x axis to about 4% to merge them and flatten them. they look ok but the spines are pointing back rather that forward. I'll try it to see if  I can make it work, but if anybody has any other suggestions??
markschum ( ) posted Mon, 11 January 2010 at 11:01 PM
www.animotions.com has a bunch of comic freestuff.
HeWhoWatches ( ) posted Mon, 11 January 2010 at 11:06 PM · edited Mon, 11 January 2010 at 11:06 PM
Is there any reason you can't use Savage Dragon's actual fin?  Take a profile picture of Savage Dragon into PhotoShop, cut out the fin, and use it to create a transparency map (and texture map).  Then just apply the transparency to a square primitive.
hborre ( ) posted Mon, 11 January 2010 at 11:11 PM
The flat square will only work in profile or distant scenes but will not look correct if viewed diagonally.
tonymouse ( ) posted Tue, 12 January 2010 at 5:18 AM
Thanks for more feed back and sugestions, I did check at animotions actually, I didn't see anything that would fit the bill, and as for a primative with transparencly, I may end up doing that but I agree with hborre it will look funky if it is any thing but profile.
tonymouse ( ) posted Wed, 13 January 2010 at 6:44 AM
I found this for now: a freebie head fin over at RunitmeDNA, I am still on the hunt for something bigger, taller and  with wider scalloped segemnts. but if this helps anybody else.[
http://www.runtimedna.com/forum/downloads.php?do=file&id=84](http://www.runtimedna.com/forum/downloads.php?do=file&id=84)
Acadia ( ) posted Wed, 13 January 2010 at 7:03 AM
Ok, don't laugh!  But have you thought about a hand fan?
http://www.runtimedna.com/RDNA-Neo-Asia-Fans.html
Embed it into the head, parent it.
of course you would have to do some work in a graphic program first so far as textures and a transmap is concerned.  You can use a transmap to scallop the edges. And some simple tricks to get the ridges of the fin.
DarksealStudios ( ) posted Wed, 13 January 2010 at 10:52 AM
Who's head do you want it for? M4?
My Store   My Gallery    Contact
DarksealStudios ( ) posted Wed, 13 January 2010 at 12:03 PM
I just made this while I was waiting for an answer for another thread. I can find a place to post it for you if you pm me.
tonymouse ( ) posted Wed, 13 January 2010 at 12:21 PM
phionix that is amazing. It is exactly what I am talking about!!! I'll PM you.
DarksealStudios ( ) posted Wed, 13 January 2010 at 12:55 PM
http://www.contentparadise.com/productdetails.aspx?pid=12071&prv=t
I'm sure I'll post it in the freebie section here sometime, but for now here it is. Maybe you can make a texture for it (maybe I'll do it at a later time). But what would be nice is if you make a good Pic for me.... 800x800 px to use for a promo pic for the freebie.
Pm me if you wanna send a pic!
DarksealStudios ( ) posted Sat, 16 January 2010 at 1:03 PM
Anybody made a pic from the head fan? I would use it for the promo!
you can get it here..
http://darkseal.weebly.com/
cause i dont know if it's up here yet, does it happen right away for freebies?
tonymouse ( ) posted Sat, 16 January 2010 at 3:23 PM · edited Sat, 16 January 2010 at 3:24 PM
I started a pic but Poser refused to re o-pen the file after I saved it and then Real  life struck and I haven't had a chance I hope to have something soon though. cuz it is perfect!! and I love it. It is so totally the savage dragon, I know some one over at animotions put up a pic there using it.
