Mon, Feb 10, 4:26 PM CST
Subject: Sketch render and color blend anomaly
mikegg ( ) posted Tue, 12 January 2010 at 10:57 PM · edited Mon, 10 February 2025 at 4:22 PM
When using sketch render and turning color blend (the last global option) all the way to the right or full on, it overlays the sketch style on the preview of the figure. I like the effect but the problem is that it also shows all the lines/guides from the preview, like the light direction lines or the ground plane, etc.. Is there any way to prevent this from happening? This is with the sketch background/density off. I only want to sketch the figure. I would love it if Poser put the sketch on top of the last render as opposed to the preview, but that doesn't seem to be possible.
I hope this makes sense. Does anyone have any solution. Try it to see what I mean. Is there a fast way to turn off all guides? I must have missed it. I can turn off the ground plane but not the others.
MIchael
EnglishBob ( ) posted Wed, 13 January 2010 at 7:49 AM · edited Wed, 13 January 2010 at 7:51 AM
Turn off everything in Display > Guides first - usually it's only the ground plane which is on by default, but best to check. If there are light guides or maybe even cameras in the way, uncheck the "visible" box in their properties.
Edited to add: you can set the sketch renderer going on any image (including your last render) if you import it as background - with nothing else in the scene, obviously. ;)
mikegg ( ) posted Wed, 13 January 2010 at 9:43 PM
Hey thanks a lot. I didn't know you could sketch a background image. I'm going to try it now.
Mike
