Fri, Dec 27, 6:18 PM CST
Subject: Render compared: Vue Standalone - Vue xStream
ossosso ( ) posted Thu, 14 January 2010 at 2:33 AM · edited Fri, 27 December 2024 at 5:46 PM
hi!
Please take a look at these two rendered images:
01
http://www.ossosso.com/public/scambio/01_vray.jpg
02
http://www.ossosso.com/public/scambio/02_vue.jpg
It's the same exact same default scene with default parameters.
The first one rendered inside 3dsmax usign vue xStream with Vray like default render engine.
The second one has been rendered using normal Vue Standalone.
Which parameters make them different?
Thank you very much!
wabe ( ) posted Thu, 14 January 2010 at 2:43 AM
Probably a gamma issue - 3DMax probably does a gamma correction while Vue does not do that.
vUeser ( ) posted Thu, 14 January 2010 at 2:56 AM · edited Thu, 14 January 2010 at 2:58 AM
Or may be Standalone has Post-FX Options ON?
(To check if this a case - just click on rendered picture in Vue and go to 'Post Render Options...')
bruno021 ( ) posted Thu, 14 January 2010 at 4:13 AM
My guess is post render options, as vUeser suggests.
ossosso ( ) posted Fri, 15 January 2010 at 2:24 AM
Me too I've thought to gamma issues, but in 3dsmax I've plaied with all possible combinations: I've switch On gamma, tried off, tried with different gamma values, tried to play with Vray Color Mapping but nothing...
About Post-Fx Option, this is the screenshot of Vue Standalone:
http://www.ossosso.com/public/scambio/03_vue.jpg
I've noticed that if I select the "main Camera" in 3dsmax (xStream version) and I click on "Edit Object" button, I can change the "Auto-Exposure" parameter, and other like "Gamma Correction", "Natural film response"... but effectively it haven't any effect on the final image, so I assume that the xStream version blocks in some way the "Advance Camera Options".
Is there any other way to apply Post-FX Options on the xStream version?
bruno021 ( ) posted Fri, 15 January 2010 at 3:24 AM
The post effets options are slim when used inside a host app, you only have "auto exposure " and "natural film response" available. Both can be toggled on or off in  the xStream options box.
