Wed, Dec 25, 7:50 PM CST
Subject: Bump map becomes transparent?
uncle808us ( ) posted Sat, 16 January 2010 at 3:24 PM · edited Wed, 25 December 2024 at 7:40 PM
Why in Vue 7 Pro Studio does my bump map become transparent when I put a light behind it? The texture for the door is a .png with transparency for the slots.
MacBook Pro OSX El Capitan Ver 10.11.6
Rutra ( ) posted Sat, 16 January 2010 at 3:42 PM
Maybe this is an artifact caused by excessive bump gain. Try to reduce the gain to, say, 0.01 and see if it still happens.
uncle808us ( ) posted Sat, 16 January 2010 at 5:00 PM
No that is not it although with 0.01 there is no bump and no problem.
Rutra ( ) posted Sat, 16 January 2010 at 5:05 PM
I don't understand. You said that "that's not it" but you also say that with 0.01 there is no problem. So... did the problem disappear with 0.01 or not?
uncle808us ( ) posted Sat, 16 January 2010 at 5:08 PM
Yes.  But then I have no bump on the object.
Rutra ( ) posted Sat, 16 January 2010 at 5:14 PM
Ok, so we know the reason: excessive bump gain, like I said.
I see two possible solutions:
a) increase the bump gain gradually until you start to see some bump but before you start to see that strange effect.
b) use displacement (tick the "displacement mapping" checkbox).
uncle808us ( ) posted Sat, 16 January 2010 at 6:46 PM
Alright I will try both tomorrow.
Rutra ( ) posted Sun, 17 January 2010 at 3:26 AM
Another thing which could be important:
I noticed you have black and white for your bump map. Don't forget that in Vue black is down and white is up. So, you're raising the white parts and lowering everything else. Is that what you really want? I would suggest that you use gray (127,127,127) instead of black. Gray is neutral.
uncle808us ( ) posted Sun, 17 January 2010 at 11:39 AM
Ahhh... That sounds like the problem, I'll try that. Thanks.
uncle808us ( ) posted Sun, 17 January 2010 at 12:55 PM
uncle808us ( ) posted Sun, 17 January 2010 at 12:57 PM · edited Sun, 17 January 2010 at 12:59 PM
No that did not fix it . This is frustrating. The over all texture is no longer a transparent .png but a solid texture .jpg
uncle808us ( ) posted Sun, 17 January 2010 at 2:04 PM
In Poser 7 it works as expected.
uncle808us ( ) posted Sun, 17 January 2010 at 5:29 PM
I solved the problem thru adding geometry a shelf above the fire box. I have no idea how to solve that bump map problem in Vue and don't have the time to fool with it. Thanks for the help everyone. :)
