Sat, Jan 25, 11:10 AM CST
Subject: poserspeak and Poser 8, does it work
jfbeute ( ) posted Fri, 15 January 2010 at 4:25 AM · edited Sat, 25 January 2025 at 11:06 AM
Considering buying poserspeak but wondering if it works with Poser 8. Has anybody tested this?
DCArt ( ) posted Fri, 15 January 2010 at 7:50 AM
Not sure .. but I had a question. What would PoserSpeak offer in addition to the Talk Designer  lip sync stuff that is already found in Poser 8?
argus1000 ( ) posted Fri, 15 January 2010 at 8:45 AM
Quote - Not sure .. but I had a question. What would PoserSpeak offer in addition to the Talk Designer  lip sync stuff that is already found in Poser 8?
As I understand it, with Poserspeak, you don't need to record voices; you buy pre-recorded voices;  you only have to type the text, and Poserspeak does it all for you.
jfbeute ( ) posted Sun, 17 January 2010 at 8:17 AM
I dit buy it and tested it. At this moment all I can say is that it doesn't work. Nor does it work on Poser Pro (the current one, not tested on 2010).
Running on a Vista Ultimate 64 environment. It tells me it creates all the frames and spends a long time without any error messages but afterwards none of the animation frames exist and the number of frames has not been extended.
Shame it looked like a usefull utility, combining actual generation of speech and creating all appropriate animation frames, including blinks and head movement.
