Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 05 4:51 pm)
If you open the PY file in Notepad what do you see in line number 4?
The error message indicates that there is a non ASCII character present. May be something like the copyright symbol or something invisible line a carriage return. Whatever it is it will probably be obvious and can be deleted or edited to something else.
If you are not sure please copy/paste line 4 to the thread and we can go from there.
Hmm,
I opened it up in EditPad Lite but I see no line numbers.
Here is the first block without the annotations:
from Tkinter import *
import poser,string
scene = poser.Scene()
class App:
def init(self, master):
self.MainButtonWidth = 9
self.FullActorList = []
self.DeformerList = []
self.MagnetList = []
self.MagnetPairsList = []
self.FigureSelected = 'no'
self.FromQuit = 'no'
self.CloneDone = 'no'
self.FullParameterList1 = []
self.Frame4ButtonWidth = 3
self.Mode = 0
self.SaveCurrentFigureName = ''
self.InactiveMags = []
self.ActiveMags = []
self.InactiveMagNames = []
self.ActiveMagNames = []
self.ReselectMags = 'yes'
self.UndoDictionary =
self.UndoCount = 0
self.MagnetDictionary =
self.MagnetCount = 0
self.DummyFont = ('Arial','1')
Here are the comments, but the only "unusual" I see is the @ in the third line ?
# Script: MagClonerV1n.py
# Author: bushi (PoserPython.com) - bushi@velocitus.net
# Description: This script mirrors magnets on a Poser figure.
# After selecting the magnets to use, you can either
# clone the magnets to the opposite side of the
# figure or delete the selected magnets.
# System: Poser Pro, Poser 5
# active scrollbox.
# scrollbox.
Maybe I should just try deleting all comments ?
![file_446900.JPG](https://live.cdn.renderosity.com/forum/threads/2792887/file_446900.JPG)
Hi, I'm still using Bushi's MagCloner script a lot and it works quite well in Poser 8.Only problem is that whenever I open or close it, I get a warning popup I have to close first.
So, is there any way I could edit it to avoid this error popups ?
This is the error I get when opening it:
