Fri, Nov 22, 7:49 PM CST
Subject: Bryce 7
gendragon ( ) posted Mon, 25 January 2010 at 2:50 PM · edited Fri, 22 November 2024 at 7:48 PM
Hi everyone!
Where can find the link for Bryce 7.
I have the original version of Bryce 6.3, but DAZ,
it didn't communicate me anything on the subject.
And I was knowing that it is a Beta test.
I was very interested in being one.
Thanks!
Anderson
AnnieD ( ) posted Mon, 25 January 2010 at 2:58 PM
If you got bryce 6 thru daz...reset your download for it and bryce 7 will be there in your downloads.  If you got it from another place, contact daz and they will tell you what to do.
I think the first beta runs out today..not sure.. and there will be another one shortly.
“For those who believe, no proof is necessary. For those who don't believe, no proof is possible.”
[Stuart Chase]
ThunderStone ( ) posted Mon, 25 January 2010 at 3:00 PM · edited Mon, 25 January 2010 at 3:01 PM
If you brought it Bryce v. 6.3 online, it should be in your DAZ download account . If not, then reset your download account. You should have it. It expires on the 10th of Feb. So you're good to go.
Hope this helps
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
gendragon ( ) posted Mon, 25 January 2010 at 3:30 PM
**Thank you very much AnnieD and ThunderStone! **
I got, I am already downloading.
Will it be necessary to uninstall Bryce 6.3?
Thanks!
Anderson
AnnieD ( ) posted Mon, 25 January 2010 at 4:33 PM · edited Mon, 25 January 2010 at 4:33 PM
no, i was told that when the install shows you the path that it wants to install to...put a 7 behind Bryce...in the folder name...and it will install to Bryce 7 folder.
thats what i did and it works perfectly
[Stuart Chase]
pakled ( ) posted Mon, 25 January 2010 at 9:59 PM
they sent a note out to most of the people who are members of Daz; I got one, even though I'm still on 5.5...;)
gendragon ( ) posted Tue, 26 January 2010 at 4:28 AM
Thanks **AnnieD ;-)
Anderson
UVDan ( ) posted Tue, 26 January 2010 at 7:10 AM
Forum Moderator
Still a bit buggy, but fun to play with.  The replicator lab will be awesome when all the bugs are worked out.
gendragon ( ) posted Tue, 26 January 2010 at 6:03 PM
Hello All!    This was my third tests, using the eco-system of Bryce Beta 7.  There is beginning, many bugs appeared, until that I learned how to dose each tool  of the echo-system of Bryce, because if he/she has a very high value, a "Crash" and you will cause will lose your work.  Each object that you to increase in the scene, save the project periodically, how many times doesn't matter goes need.   When it applies an eco-system, go applying little by little and saving, this way, you will avoid the "crashes."  I built this scene after 7 hours of test, because a crash happened and logically, I lost the last command. Everything built in Bryce 7, except for the atmosphere, I used a sphere mapped with a sky of 360th + configurations in the atmosphere of Bryce and several lights.  I wait to have helped and that have liked the result.    Anderson "Gendragon"
