As for how to get clothes to stick, simply click on any part of the clothes, click on Figure, then click "Conform to"... then select (usually) Figure 1. Voila, the clothing conforms. As for how to prevent skin from sticking out through the clothes, you can either select the body part under the clothes (if it's fully concealed), press Ctrl-I, and uncheck the "Visible" box, or if the body part is only partially covered (like a shoulder only partially covered by a t-shirt), you can either try to use "taper", if available, to make the sleeve, for example, a little wider, or you can clean it up after the render, in Photoshop or the like.
Remember, kids! Napalm is Nature's Toothpaste!
Hiya....why not download the manual from the Poser site? It's a comprehensive manual and it has a tutorial section. If you're really cheeky you could print it out and have it spiral bound at work like I......would have done if that wasn't a misuse of company resources ;). There are lots of excellent online tutorials as well. Good look with the most addictive piece of software in the world Mon
Total newbie here. I'm using Poser on a friend's computer and have no manual, so I'm stumped with some very basic stuff. How do you get clothes to stick to a person? When you move the person, the clothes stay behind. And what do you do when skin shows through spots in the clothes? Also, after you make an animation, how do you switch it into Lightwave? Please help.
