Tue, Feb 4, 8:41 AM CST
Subject: pp2 to obj ?????
3eighty ( ) posted Thu, 04 February 2010 at 5:34 PM · edited Tue, 04 February 2025 at 5:50 AM
Isn't there a tool that converts a pp2 to an obj?  Or am I having a senior moment?
Thank You
shuy ( ) posted Thu, 04 February 2010 at 5:38 PM
Tool = Poser
File => export => wavefront obj => select subset
lmckenzie ( ) posted Thu, 04 February 2010 at 5:45 PM
Shaper - can do it plus it is a nifty prop viewer:
http://www.eurus.dti.ne.jp/~masasi/DOWNLOAD/index.htm
Or
GeomStripper
http://www.renderosity.com/mod/freestuff/details.php?item_id=48560
markschum ( ) posted Thu, 04 February 2010 at 6:24 PM
If you just want an obj use the export.
If you want to externalize your geometry (have a seperate obj) then use geomstripper.
3eighty ( ) posted Thu, 04 February 2010 at 11:47 PM
lmckenzie> Those are the exact ones I was thinking about...Thank you to all of you...Sometimes I want to do something without opening the whole Poser program..
seachnasaigh ( ) posted Fri, 05 February 2010 at 12:32 AM
Attached Link: Geometry Stripper
John Hoagland's free ***Geometry Stripper*** is a little stand-alone utility app which strips out an OBJ from a PP2, leaving you with a separate geometry mesh (obj) and a new PP2 which remote-references the obj. Many places which have freebie forums require separate OBJs.
nickedshield ( ) posted Fri, 05 February 2010 at 8:26 AM
kawecki's Prop ViewerV2.0 can save as an obj. Free stuff.
pakled ( ) posted Fri, 05 February 2010 at 10:30 PM
I think Senosofts' P3do has a plugin to do object viewing, but I could be wrong...
