Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
You didn't specify, but seem to be implying how to do these with nodes.
Q1) Are you looking for procedural materials?
Q2) You said "avoid ... remap". So these items are currently UV mapped? Or did you actually mean "avoid ... mapping" and they are not currently UV mapped?
Not mapped at all, and frankly I'm becomming a bit weary lately of splitting objects in UV Mapper Pro, and then having to repair dozens of missplaced facets before I can proceed with the mapping proper. If a procedural can be made fairly easily to handle most of the texturing without having to go to all the rigamarole of creating custom textures and/or mapping to some know existing object or clothes, then so much the better.
dph
Well, sorry to say, a procedural needs UV coordinates, too. It isn't possible to create a realistic and consistent pattern on a curved surface without UV coordinates.
A few years ago there was an interesting discussion about how cloth should be UV mapped in the Node Cult, motivated by exactly what you're asking for - plaids, tweeds, etc.
http://www.runtimedna.com/forum/showthread.php?t=24888
Adorana gave us a thread showing how to do it right.
http://www.runtimedna.com/forum/showthread.php?t=25017
Pieces of cloth must be "cut" from a UV mapped rectangle, and then bent and "sewn" into place like real cloth. If not, then there are completely unmotivated stretched areas - the sort of stretching that just doesn't happen in real cloth.
However, if you have something UV mapped, you can get some pretty realistic cloth procedurals for it using matmatic and my Loom script.
Early cloth work, before the loom: http://www.runtimedna.com/forum/showthread.php?t=24029
Later:
http://www.runtimedna.com/forum/showthread.php?t=25810
About the only way to get away from UV mapping is PTex: not quite Poser-compatible, though...
OK, say that I managed to Split the Object in UV Mapper Pro, and laid the two halves out side by side in a planar map, instead of going to all the bother of moving vertices to comply with some known dress or coat texture, can I use a procedural to create a cloth instead that will look good and realistic?
Basically, while I don't mind doing a rough UV on these, I don't want to spend the next month just moving vertices on clothes. I want to get away from mapping for a while and do pictures instead.
dph
Sure, you can. You can use a seamless tiled image, too. Either way, the shader will fill the entire UV map with a pattern and the individual pieces of cloth will show some reasonable subset of the pattern, which is what real clothing does.
The matmatic Loom will make realistic woven cloth of any pattern and any colors you desire. It can do anything a real loom can do.
http://www.runtimedna.com/forum/showthread.php?t=25805
http://www.runtimedna.com/forum/showthread.php?t=25832
Bagginsbill, sometimes I think that you can create face texture with mathematic functions ;)
At the moment I can understand simple nodes like plaid
http://www.castleposer.co.uk/articles/material_plaid.html
The link mark gave for matmatic is malformed.
Here's the correct link.
http://sites.google.com/site/bagginsbill/free-stuff/matmatic
Use some sort of low frequency noise node to drive the offsets on the Image_Map node. Like this.
You'll have to experiment to find the right sizes and amounts. It all depends on the object you're using.
I know that this has been discussed in the past, but how would one go about setting up MAT shaders for Heavy wool fabrics such as Harris Tweeds, Scots Tartons, and/or possibly even lace. This is in order so as to avoid the long process of having to remap some custom new dynamic clothes for either Judy, Posette, or Dork.
dph
