Thu, Jan 9, 6:48 AM CST
Subject: How do you create a hide/show pose for a figure?
cocco ( ) posted Fri, 12 February 2010 at 9:49 AM · edited Tue, 07 January 2025 at 10:26 AM
Sorry but I've never done this before,I have some figures that need to have such poses to work correctly,eg a boot that need to have M4 feet hidden.How I can do that?Is it a complicated thing?Thanks a lot
cspear ( ) posted Fri, 12 February 2010 at 10:02 AM
It would look like this:
version
    number 7.0
actor rFoot:1
              off
actor lFoot:1
              off
If you copy everything between the quotes, paste it into a text editor and save it with the .pz2 extension it should work... change 'off' to 'on' to create a 'show' pose. Obviously can be adapted for any other body parts.
Good luck!
PoserPro 11 - Units: Metres
Adobe CC 2017
cocco ( ) posted Fri, 12 February 2010 at 10:06 AM
thanks, I just have to write these lines?
dadt ( ) posted Fri, 12 February 2010 at 10:09 AM
No need for a pose, for any body part just select it then in its properties deselect the box labelled "Visible"
cspear ( ) posted Fri, 12 February 2010 at 10:12 AM
Yes, start at the first " { " and end at the last " } ". Make sure you retain the indents, they seem to be important.
I'd recommend Notepad ++ for this kind of stuff.
Adobe CC 2017
cocco ( ) posted Fri, 12 February 2010 at 10:13 AM
It's that if the body parts are more than one it would be better to have a pose that hide those parts
cocco ( ) posted Fri, 12 February 2010 at 10:19 AM
but i have to edit the cr2 to create this file?
grichter ( ) posted Fri, 12 February 2010 at 10:44 AM
No. create a text file called ToesHide.pz2 that looks like this. Save to you pose folder-directory. You can put it in another folder in the the pose folder-directory like I have called HideBodyParts.
Case of the letters is important when specifying a body part rToe will work whereas Rtoe or rtoe will not.
version
    number 4
actor BODY
actor rToe
    off
actor lToe
    off
figure
Gary
grichter ( ) posted Fri, 12 February 2010 at 10:48 AM
In the free stuff I found  one that I have never used that you can download and look at and maybe use
http://www.renderosity.com/mod/freestuff/details.php?item_id=28616
Gary
cocco ( ) posted Fri, 12 February 2010 at 10:57 AM
thank you very much!
PhilC ( ) posted Fri, 12 February 2010 at 10:59 AM
Just FYI.
Line indentation in Poser files is only to make it easier for humans to read. Poser does not actually require it.
However Poser Python scripts DO take account of the indentation. (As do all Python scripts).
nomuse ( ) posted Fri, 12 February 2010 at 5:39 PM
Another FYI:
If you make a hide pose, it's best to make an un-hide pose as well.   Looks just like the example, only the key word is "on" instead of "off."
And lastly....
Although there is not even an ad-hoc standard, many creators attempt to adhere to some variation of the below;
MAT poses change materials
MOR poses adjust morphs
SET poses are multi-function-poses, to change joint params...or hide/unhide body parts.
(Oh by the way...if you didn't figure it out already, a pose file is nothing but a text file -- normally .txt -- that's had the suffix .pz2 applied instead.)
JHoagland ( ) posted Sun, 14 February 2010 at 3:17 PM
If it helps, feel free to use my hide/ show hands and hide/ show feet poses as a starting point.
VanishingPoint... Advanced 3D Modeling Solutions
