You can right click the arrow beside the dial in the properties pannel, and change the settings of the dial to always be one. Then save the CR2. You do not need to edit the CR2 directly with this method.
I am at work, could some one show a screen shot of that?
LMK
Probably edited for spelling, grammer, punctuation, or typos.
Well, you could make the change in the dial settings, save it to a CR2, look to see how the new settings change the new CR2 and then copy thos settings to the original CR2.
Or, someone may come along that knows what to change, and save you the trouble.
LMK
Quote - ... I want this morph to be set to 'on' at all times...
In the relevant targetGeom channel:
forceLimits 1
min 1
max 1
"forceLimits 1" tells Poser to respect the limits set in the two lines below. "min" and "max" are the actual minimum and maximum values the channel is allowed to have. "initValue" is the value that the channel will be set to when you use the Restore command, but this will not override forced limits, and so is not relevant in this case.
Ok, Say I have an adjustment morph in an article of clothing that I'm gonna hide, and I want this morph to be set to 'on' at all times...in other words if it wasnt hidden, I'd want it always dialed to 1.000000.
What piece of code in the cr2 do I change to make this happen ? ( I already know hidden )
Ever stop to think, and forget to start again?
