Thu, Feb 13, 4:38 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Subject: OcclusionMaster
indianlight ( ) posted Tue, 23 February 2010 at 11:57 PM · edited Sun, 09 February 2025 at 7:04 PM
when go to run script , can`t find tk84.dll , whats missing ? ,got Poser 7
indianlight ( ) posted Wed, 24 February 2010 at 1:02 AM
Traceback (most recent call last):
  File "C:Program Filese frontierPoser 7RuntimePythonposerScriptsScriptsMenuRealism KitsOcclusionMaster.py", line 19, in ?
    from Tkinter import *
  File "C:Program Filese frontierPoser 7RuntimePythonliblib-tkTkinter.py", line 38, in ?
    import _tkinter # If this fails your Python may not be configured for Tk
ImportError: DLL load failed: The specified module could not be found.
This what it said .
semidieu ( ) posted Wed, 24 February 2010 at 2:09 PM
Do you have the latest service release of Poser 7 ? If I recall correctly, the unpatched version of Poser 7 was having difficulties with tk.
nruddock ( ) posted Thu, 25 February 2010 at 3:19 PM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2787364
That error message has a couple of possible causes, see linked thread to see if you can determine which one you've run into.
indianlight ( ) posted Thu, 25 February 2010 at 7:34 PM
well , i took the long way , i moved poser onto backup hard drive , then reinstall poser , install update , then the scripe , and it works , now got to install all that content ,,,,,about 23 gig. .....   thank for the replys ..
markschum ( ) posted Fri, 26 February 2010 at 12:09 AM
You should be able to copy the runtime across, do it as geometries, textures and then libraries  and you should restore content without disturbing python or anything else.
