Sun, Dec 1, 12:00 AM CST
Subject: Poser Pro2010 can not find a resource it aparently wants me to have
Laylah ( ) posted Thu, 11 March 2010 at 9:50 PM · edited Fri, 29 November 2024 at 1:05 AM
I just reinstalled Poser pro 2010 for the second time and added all my runtimes again and i have a darn whole lot. Unfortunately whenever I close the program then restart it it will give me the following error, the error was also the reason I reinstalled it to begin with and I am kind of hoping it an be fixed without anymore deleting and starting over adding 56 seperate runtimes is getting on my nerves and is actually quite time consuming. Damn my runtime ocd :(
So this is the error message I am getting.
Any ideas if I can find that file somewhere and add it manually? Running the Poser Pro 2010 on a W7 64 bit system.
markschum ( ) posted Thu, 11 March 2010 at 10:01 PM
that looks like a failure in the xrc menu functions that became available in Poser 8. I dont have Poser 8 or pro so I cant go further with it.
You can just readd your runtimes after a reinstall. Copy the main one somewhere first.
uli_k ( ) posted Thu, 11 March 2010 at 11:07 PM
You're not copying everything into the Poser Pro 2010 installation location, are you? This looks like Runtimeui was overwritten by older files.
Laylah ( ) posted Thu, 11 March 2010 at 11:15 PM · edited Thu, 11 March 2010 at 11:17 PM
No I avoid doing that by re-adding all my runtimes by hand from an external hard drive, then reinstall all the gen 4 stuff and python scripts etc completely fresh into the new Poser Pro 2010 folder..
Going to see if I can maybe get a fresh install od Poser Pro in a different location and then move the file where it belongs by hand, if it will install. But that will wait till tomorrow way too tired to attempt it now thanks for the help!
Magic_Man ( ) posted Fri, 12 March 2010 at 6:45 AM
With regards the runtimes, find the .xml file that contains details of your runtimes and make a copy. You can then use this rather than have to enter them all again manually.
Laylah ( ) posted Fri, 12 March 2010 at 6:52 AM
I found the file manually and added it to the folder and that worked. The error message is gone and it works like a charm, and I will keep the file in mind and keep it around to add in the future never struck me to do that and spare myself a lot of tedious work. Thanks all!
