Sun, Feb 9, 7:34 AM CST
Subject: Setting up network render in PoserPro 2010
hobepaintball ( ) posted Fri, 12 March 2010 at 11:50 AM · edited Sun, 09 February 2025 at 7:23 AM
I have an existing small render farm I use for Vue consisting of 5 dual core pcs running 32bit Vista. I would like to use the same pcs for my Poser network renders, do i have to upgrade them to 64bit OS? Or does only the renderinitiator need to be on the 64bit OS?
I forgot to mention the Main PC, running Poserpro2010 is 64bit win 7 quad core 8 gig ram
IsaoShi ( ) posted Fri, 12 March 2010 at 6:59 PM · edited Fri, 12 March 2010 at 7:11 PM
You do not have to upgrade them to 64bit OS - QueueManager runs on 32bit OS.
Neither does the initiator have to run on 64bit OS, though as you have one it's the sensible thing to do.
(edited to correct error)
3DNeo ( ) posted Sat, 13 March 2010 at 5:44 AM
Quote - I have an existing small render farm I use for Vue consisting of 5 dual core pcs running 32bit Vista. I would like to use the same pcs for my Poser network renders, do i have to upgrade them to 64bit OS? Or does only the renderinitiator need to be on the 64bit OS?
Yes, it should work, but keep in mind that unless you have a 64bit OS your system will be limited to the amount of memory available on those computers. Also, I'm sure you know this but only the Pro and Ultimate versions of the Windows OS will take advantage of more than one CPU.
Jeff
Development on: Mac Pro 2008, Duel-Boot OS - Snow Leopard 10.6.6 & Windows 7 Ultimate 64bit, 2 x 2.8 GHz Quad-Core Intel Xeon , 10GB 800 MHz DDR2 RAM, NVIDIA GeForce 8800GT.
aquiavic ( ) posted Sat, 13 March 2010 at 7:58 PM · edited Sat, 13 March 2010 at 8:00 PM
I have Home premium Vista 64 and it uses 4 cores on Carrara 7 Pro and Vue 8 Inf.
also Window 7 home premium 64 uses 4 cores.
