Sat, Feb 1, 9:28 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 9:10 pm)
Subject: PPro 2010: Annoying bug when rendering in background.
Vestmann ( ) posted Tue, 16 March 2010 at 7:11 PM · edited Fri, 24 January 2025 at 7:23 AM
I´m having trouble when rendering in background.  Sometimes the background renderer stops calculating new renders.  Instead it just shows it last render...
For example, let's say I just finished a render that's a closeup of V4's head. We can call it Render A.  Now I move the camera, do some changes etc. and hit render in background.  Instead of starting a new render process it just shows Render A again...
I haven't been able to find out what's causing this and the only solution seems to be to restart Poser.  Anyone know what this could be?
 Vestmann's Gallery
Zaycrow ( ) posted Wed, 17 March 2010 at 8:35 AM
Rendering in separate process? If yes, try turning it off.
Vestmann ( ) posted Wed, 17 March 2010 at 8:51 AM
 Thank you Zaycrow.  I'll try that next time the problem presents itself.
 Vestmann's Gallery
ratscloset ( ) posted Wed, 17 March 2010 at 1:19 PM
Does the Render Progress at the top say it is done? It will not show the new Render until it is done. Render in Background is always a separate process. Changing that only affects Renders in the Program.
ratscloset
aka John
Vestmann ( ) posted Wed, 17 March 2010 at 1:48 PM
Quote - Does the Render Progress at the top say it is done? It will not show the new Render until it is done. Render in Background is always a separate process. Changing that only affects Renders in the Program.
Thanks for the tip about the Progress bar.  I´ll be keeping an aye on it...
 Vestmann's Gallery
Ajax ( ) posted Thu, 18 March 2010 at 6:54 AM
I've noticed the same problem and waiting for the progress bar to finish doesn't help.  Looks like a genuine bug.  One of us should probably report it to SM.
Vestmann ( ) posted Thu, 18 March 2010 at 9:57 AM
 I've contacted SM about this.
Sometimes the progress bar doesn't finish even though the render has finished (you can't stop the render and FFRender64.exe process has ended).   Does anyone know why that happens?  Does it matter?
 Vestmann's Gallery
