Sat, Jan 11, 12:19 AM CST
Subject: Looking for a fishnet-like dress for V4
Holli ( ) posted Mon, 22 March 2010 at 5:22 PM · edited Fri, 10 January 2025 at 9:25 PM
I am looking for a fishnet like dress (can you call it dress?) like you see on the attached picture. It should be for V4 or V3 maybe.
bagginsbill ( ) posted Mon, 22 March 2010 at 5:41 PM
You could make any dress (or poncho?) look like that with a procedural shader. Well, close anyway. There won't be a nice hem, but it might suffice. I'm cooking a demo now.
bagginsbill ( ) posted Mon, 22 March 2010 at 5:57 PM · edited Mon, 22 March 2010 at 5:57 PM
I used the Poser Hi-Res cloth plane here. This shader may or may not work well for you depending on how the cloth is UV mapped.
I bet somebody could make a simple disk prop (a circle with a hole), hi res, with simple rectangular UV mapping that would work pretty well.
I added the UV offset nodes to make the net be diagonal, but that isn't strictly necessary, especially with a circular prop.
You will have to experiment to find the best Tile_Width and Tile_Height to scale the pattern to the UV mapping of your clothing.
It is also possible to procedurally add a hem at the neck and at the edge of a circular disk prop. That would be (calculating in my head) approximately 11 more math nodes.
