Forum Moderators: RedPhantom
hborre is a lot smarter than I; and his answer is, of course, correct. But just in case you are not familiar with Poser..... here is a little detail ( I do what you are describing all the time)
7.name and save the head. Use this model in your modeling program. You cannot change the poly count, poly order..... poser will not reorder well even though it has an option to try and fix the order.
....and what is thew biggest PAIN OF ALL, IMO, is you cannot split the mesh in half, model it, then mirror the half. That will mess up the polys for Poser.
anyways, when you are done you will want to save as wavefront OBJ.
a morph dial will appear , named the same as your OBJ, in the parameters tab, under "Morph"
10. crank the morph dial; enjoy morph.
______________________
"When you have to shoot ...
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
http://www.renderosity.com/homepage.php?page=3&userid=580115
BTW!
this is the " export the head only" method , and you asked to move all of V4 -
you can certainly move all of V4 ...but then there are a few more considerations .
one of the biggest considerations is - you can move all of her parts out as one OBJ, but you will probably not want to "weld seams" on the way out of
poser - b/c you have to save the parts OUT of your modeling program SEPARATELY for poser to accept morph targets.
I would definitely export and work the head only -
just remember not to move the posiion of the botom most edges of the head - cuz if you do you will maybe get a messy fit to the top of neck
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
If you say which modelling app you're going to be using, it would be possible to point you to the known gotchas when making morphs for Poser with it.
Some other general points :-
Make sure you do a round trip (i.e. import something back into Poser) before spending a long time doing a morph only to find it gets mangled.
If you alter the eye sockets, you'll have to correct the eye postions, don't fall into the trap of trying to make this correction with a morph, look for posts on how to do this with ERC (lesbentley / PhilC and perhaps others)
If you move on to morphing more than one body part, you may want to use the original OBJ (from the Geometries folder or where ever) rather than export from Poser.
Hunt down the scripts for import FBMs.
Thank you, santicor, for elaborating further on my short answer. I was stepping out and pressed for time. The workflow appearing on the other posts indeed point out the critical details how to correctly export and import for morphing V4's facial features. Nruddock does caution that too much alteration of the mesh will cause problems later. So carefully consider what you are altering and how to approach the project. You can get very satisfactory results if you think it through.
Attached Link: http://www.drgeep.com/p4/morwings/morwings.htm
Here's a direct link for you that might help. ... See Page 10.
View it in good health.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Thank you all. All very informative.
Sorry for not mentioning the outside app. Its Max. The clue would be at the bottom of my post. lol
<strong>bandolin</strong><br />
[Former 3DS Max forum coordinator]<br />
<br />
<a href="http://www.renderosity.com/homepage.php">Homepage</a> ||
<a href="http://www.renderosity.com/mod/sitemail/">SiteMail</a> ||
<a href="http://excalibur.renderosity.com/mod/gallery/browse.php?user_id=70375">
Gallery</a> || <a href="http://www.renderosity.com/mod/freestuff/index.php?username=bandolin">
Freestuff</a>
<p><em>Caution: just a hobbyist</em></p>
So, am I to understand that figures with expressions such as smile and frown and such have dozens of head geometry somewhere. Or is that done differently?
<br />
Freestuff</a>
and to follow up on that thought - you are creating a brand new set of morph data by means of creating a model and so in the beginning stage you want a phyiscal vieable object to work with, thus you are creating an OBJ that you can work on...after you have burned those morph coordinates in somewhere ( there are many ways of doing this,.... Dr Geep mentions that morph coords are in the deltas of CR2) the geometry is no longer really needed as a morph target.
I use external PMD as a means to make a psuedo "injection morph" pose, myself.
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
....... and so I have to keep the goemetries
(Wow this website crashed hard during my post)
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
Can anyone direct me to a tutorial or information that discusses how to export V4 into a 3rd party app to make a facial morph and then reimport it to customize V4's face?
I'm sure this has been asked many times, but I can find any thread here after a search.
